I just asked this question but I forgot to mention one thing
2003 JEEP LIBERTY
156,000 MILES • 6 CYL • 4WD • AUTOMATIC
CBOISVERT
I just received the answer the answer to the problem I am having with my jeep. He said if there is no coolent leak to try something, but it is leaking antifreeze a lot faster than I can put it in. Here is my original post.
Okay so I had a friend change my thermostats and when he was finished my jeep was leaking antifreeze. He then told me he didn't know if he had put it in there right or if he had tightened the radiator house all the way. He then went to try and fix it again and broke a bolt where the thermostats would go. He told me it wouldn't be a problem and he would fix it the next day. I drove it to work the following day and the temperature gage went all the way to high. When I went to leave work my jeep started making this horrible knocking noise and I could feel it in the gas pedal. Then once again my temperature gage went all the way up. I pulled over and had it towed to my home. Any idea what is wrong with it please help!!! Thank you!!!
Dec 5, 2013 at 3:06 PM
SATURNTECH9
  • 30,869 POSTS
So where is the coolant leaking from the thermostat housing?
Dec 5, 2013 at 3:13 PM
CBOISVERT
Yes that is where it's leaking from since he broke the bolt.
Dec 5, 2013 at 3:19 PM
SATURNTECH9
  • 30,869 POSTS
Thats why its leaking only one bolt holding the Housing down.your going to have to remove the bolt fix the hole to fix the leak.
Dec 5, 2013 at 3:29 PM
CJ MEDEVAC
  • 11,004 POSTS
THE KNOCKING AND VIBRATIONS YOU MENTIONED ......WAS YOUR JEEP SCREAMING OUT THAT YOU MAY HAVE CAUSED SOME ENGINE DAMAGE
HE MAY HAVE TO GO IN FOR SOME HEAD/ HEAD GASKET SURGERY AND MAYBE OTHER FIXES TOO.
DEPENDING ON HOW FAR YOU DROVE HIM, WITH HIM OVERHEATED MAY HAVE A BEARING ON THE EXTENT OF DAMAGE YOU HAVE DONE
..........BAD FRIEND!......BAD FRIEND!......FRIEND?????
KEEP US POSTED ON WHAT YOU FIND OUT.....WE ALWAYS ARE HERE
THE MEDIC
Dec 5, 2013 at 5:48 PM
