Rough ride on bumps and uneven road small road?
2011 AUDI Q7
170,000 MILES
JAVED KHAN
  • 7 POSTS
I have changed the sway bar bushing front and rear arm link bar.
Also change front right jumping strut.
Car has air suspension also I have change compressor and solenoid valve.
Mar 10, 2023 at 11:02 AM
Since it has air ride suspension, does it seem to be sitting at the correct height and even? Does everything related to the suspension seem to be operating?
Also, a rough ride can also be related to the tires or tire pressure. Have they been inspected?
Does the roughness seem to be from both the front and rear? Are there any noises associated when you experience the issue?
Mar 11, 2023 at 8:47 PM
JAVED KHAN
  • 7 POSTS
Dear Jacob,
Thank you very much for the reply.
I have checked there is no fault code.
There is no leakage.
Height seems okay suspension going up and down.
I have changed to new tires Kumho brand.
Yes, there is leak in steering rack.
Regarding the noise I can feel grinding .
But main issue is when go bumps I feel like hard jerk something is loose checked everything nothing is loose
Even local mechanic said lower arm bushing fine it’s 11-year-old car as I said I have change only one front air suspension only do I have to change both together.
Please help what you suspect.
Mar 12, 2023 at 1:35 AM
The grinding noise has me the most interested. Is the grinding only when hitting a bump or does it happen all the time while driving?
Also, if you feel a jerk when hitting bumps, does it pull you in one direction? Has anyone checked the wheel bearings for wear?
Mar 12, 2023 at 2:01 PM
JAVED KHAN
  • 7 POSTS
Yes sir,
They check bearing is okay grinding noise sometimes.
Is it possible front strut has problem I have change only refurbish one do I have to change both?
Sorry to bother you again.
Mar 12, 2023 at 7:29 PM
You are not bothering me at all. Please feel free to ask as much as you want. LOL
Normally, they should be changed in pairs, but with this system, changing one should be fine. However, I still don't see how the shock would be causing a grinding noise. Also, was the vehicle aligned after the work was done?
Mar 12, 2023 at 7:47 PM
JAVED KHAN
  • 7 POSTS
I will get vehicle aligned and let I know.
I think I have done it before changing.
Mechanic did re programming and adaptation.
But again, I will do.
Mar 12, 2023 at 7:57 PM
Let me know what you find. I'm interested in knowing. Also, when front struts are replaced, an alignment should be performed.
Mar 12, 2023 at 8:25 PM
JAVED KHAN
  • 7 POSTS
Sure.
But at higher speed I don’t feel car smooth .
Low speed has rough ride like tire has very over inflated feeling very hard.
Let me get it checked alignment.
I am keeping PSI 35 each tire.
Mar 12, 2023 at 8:32 PM
The pressure you indicated is good. Something isn't making sense. By any chance, did they leave the suspension in the tow mode which would cause it to have a stiffer ride?
Mar 13, 2023 at 7:59 PM
JAVED KHAN
  • 7 POSTS
No, I have it on comfort mode via Mmi.
Mar 13, 2023 at 8:44 PM
JAVED KHAN
  • 7 POSTS
Also, Jacob could you suggest me fault code reader for Audi I can buy on Amazon. Is it worth buying?
If you have any suggestions.
Mar 13, 2023 at 9:02 PM
As far as a scan tool is concerned, it really matters what you want it to do. Are you looking for something that provides powertrain codes and the ability to clear them?
I attached one that is a good price for what it can do. Take a look below.
See pic below.
Mar 14, 2023 at 3:21 PM
