Bad plug shorted out and lost all lighting throughout ceiling of van
1991 FORD E-SERIES VAN
136,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
ANDREW CABANAS
I have plugged in a bad plug in the rear ceiling of the van into a 12 volts car outlet. It shorted and lost the lighting through the ceiling of the van. I have checked the fuses and can't find any that are bad. Is there an in line fuse or something that I'm not noticing?
Feb 28, 2019 at 2:30 PM
STEVE W.
  • 15,113 POSTS
Welcome to 2CarPros. Is this a conversion van or extended work van? The wiring diagrams I have don't show a rear outlet from the factory. I have seen them in conversion vans though.
The OEM lights are on fuse #8 which is a 15 amp fuse. If it's a conversion van they usually hide the upfitter fuse box behind a trim cover. Most are behind the drivers seat in the sidewall.
Feb 28, 2019 at 6:23 PM
