no power to blower motor resistor?
2004 FORD CROWN VICTORIA
77,000 MILES • 4.6L • V8 • RWD • AUTOMATIC
BWT98
My blower motor won't come on at all. I checked all the fuses and they are all good. I pulled the blower motor resistor and have no power to that any suggestions?
Aug 24, 2014 at 5:06 PM
MLDANIELS2000
  • 227 POSTS
It sounds like you have a blower motor relay that is not working which is located under the hood in the fuse panel. I would swap it out and then see if the blower motor has power and ground, this guide can help.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Check out the images (Below). Please let us know what you find.
Aug 24, 2014 at 5:27 PM
BWT98
Really? There is no power to it? What good is tapping on it going to do the resistor is seperate from the blower motor
Aug 24, 2014 at 5:34 PM
MLDANIELS2000
  • 227 POSTS
There is a relay for blower motor in junction box behind battery. Pull the relay and check to see if it's burnt. Also it can be the control head here is the wiring diagrams so you can see how the system works.
Aug 25, 2014 at 11:13 AM
