Defrost has no air blowing
2007 HYUNDAI TUCSON
200,000 MILES
JOHN LAVERS
I have no air at defrost.
Jul 17, 2016 at 6:59 AM
HMAC300
  • 48,601 POSTS
your mode actuator may be the problem try pulling HVAC fuse inside car for sixty seconds with key on. then reinstall it may reset it otherwise check to see if it gets power or not. it may be bad.
Jul 17, 2016 at 8:34 AM
MAXIMILIAM
  • 436 POSTS
There is nether fuse there with HVAC on it.
John Lavers
Jul 18, 2016 at 2:26 AM
MAXIMILIAM
  • 436 POSTS
What size would the fuse be?
John Lavers
MAXIMILIAM
  • 436 POSTS
And I have a problem with window motor on the right side theirs power going to it all the it wont go down.
John Lavers
Jul 18, 2016 at 2:27 AM
MHPAUTOS
  • 31,937 POSTS
The actuator shown in the earlier response is known for failing, you can unplug it and check for power at the plug when defrost is commanded.
Jul 23, 2016 at 2:22 AM
