There is heat blowing from the midway vents but no heat to front defrost or lower feet vents?
2016 JEEP PATRIOT
180,000 MILES • 2.4L • 6 CYL • AUTOMATIC
BRENNERBRANDON
When I turn the heat on in the vehicle and set it to the Midway vents it blows out warm air when I switch to defrost it instantly goes cold as well as when I switch to the lower vents.
Oct 8, 2023 at 8:37 AM
That is an interesting one. When you switch to defrost or the floor, does the airflow direction change accordingly?
I ask because there is a mode door actuator that is responsible for airflow direction and a blend air door actuator that is responsible for air temperature. What you described ties them together, which is very odd.
Oct 8, 2023 at 2:25 PM
