I did all the basics load test the battery check for good battery, connection, and not any problems except having a slight hesitation at hard throttle and a problem with getting a Bluetooth connection. I found the service bulletin for this problem and started doing a voltage drop test on the battery cables, but they all seemed okay but I really need a wiring diagram for the body control module and a pin out. And maybe there’s a flow chart to trace this problem being an open circuit and having a service bulletin. This seems to be a very common problem.
Dec 10, 2024 at 1:40 PM
