only run with starting fluid gas is not going threw the fuel injectors?
2001 OLDSMOBILE ALERO
140,000 MILES • 3.4L • 6 CYL
RICK H. FULLER
I have a 2001 Olds alero V6 3400 engine. I have put in fuel thit pump, fuel filter ,fuel enjectors 3-4 new censers main compute, thinking next try a ecm or a pcm what do you think
Mar 18, 2026 at 7:23 PM
Hello, so when you turn the key on, do you hear the fuel pump come on for about 5 seconds inside the fuel tank? Also, does the security light flash while you are cranking the engine over? I would unplug the MAF sensor as well, if this sensor is bad it wont allow the fuel pump to kick on, please go over this video a s well.
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t
Please upload a short video in your response of the problem, so I can see what's going on. Please go over this guide and get back to us. Ken
Mar 19, 2026 at 11:09 AM
