Check engine light is on
2003 TOYOTA COROLLA
200,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
CRAIGP1148
  • 4 POSTS
I connected a obd2 to the car the wifi connects but it will not communicate with the car. It keeps telling me it cannot communicate with the car so I cannot get rid of the engine light. I have tried three different obd2 connectors same problem with all of them.
Nov 10, 2018 at 4:45 AM
There is a fuse ODB 7.5 amp that needs to be checked and if okay please check the ground at the ALDL connector. Here is a guide to help check for power and ground with the wiring diagrams for he connector so you can see how it works and the fuse location as well:
Nov 12, 2018 at 11:10 AM
CRAIGP1148
  • 4 POSTS
I have checked the fuse that is okay, obd2 powers up and when it says linking to car it does not link. When I turn the key of it says turn key on to connect but it will not link to car.
Nov 15, 2018 at 6:47 PM
Does the car run? Here are other fuses you should check for power in the PCM diagrams. I would check the grounds as well. It sounds like the computer might be bad. Check the EFI relay as well.
and
Nov 16, 2018 at 1:00 PM
CRAIGP1148
  • 4 POSTS
Hi Ken, the car starts fine if I have tried everything but still will not connect to the obd11. If I pull the battery lead of when I start the car the engine light goes off, but when I switch it off again and start switch the engine light stays on.
Nov 18, 2018 at 5:15 AM
If the wiring is okay and the scanner is working then the only thing it leaves is a bad PCM. I would try a used/rebuilt one and plug it to see what happens. Here is the location.
Nov 19, 2018 at 11:41 AM
