Codes p0019, p0016, and p0018 after a JDM swap?
2015 SUBARU WRX
55,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • MANUAL
BENITOV0415
  • 6 POSTS
I just recently got a jdm swap. The car runs fine but I will say that it shakes a bit on idle. I ordered new 4 VVT valves for the car. I tried putting my old ones from my old car but it still gets the same engine lights. I checked the VVT correlation values on a scanner and they read over 100. The values were both 113 and never moved. I just wonder if this is common.
Oct 11, 2023 at 5:35 AM
The codes are all related to camshaft/crankshaft correlation issues. I looked through each one and other than a different bank or cam, the tests are very similar. So, I attached the diagnostics below for the P0016. Take a look through the diagnostics and let me know if you are comfortable performing them or if this is something you have already done.
See pics below.
Oct 11, 2023 at 7:42 PM
