I get nothing....no lights, no crank, no beeping when u open the doors
2001 FORD EXCURSION
191,000 MILES • 3.5L • V10 • 4WD • MANUAL
MSMYDAVIS
First off, the battery is good. I've boosted battery and replaced with a charged new battery.
Got in truck to go, crunk up fine. The one minute late it just shut off. The only thig that was on was a vlinking theft light in the dash. If you turned over the key there is no attempt to crank, silence. There were no lights. No door ajar beeping, no radio or normal dash lights. It was late, I did nothing. The next day, I attempted to trouble shoot. I assumed it was the battery. When a boost didnt work, I took the battery ti locals to have it charged. Battery reading good. Still nothing. I bought a new battery still nothing. Even when cables are connected for some time, there is still no lights, horn no power and any such. Whats wrong with it?
Oct 7, 2014 at 7:54 PM
SATURNTECH9
  • 30,869 POSTS
Have you checked all the fuses in all fuses boxes yet?
Oct 7, 2014 at 8:56 PM
MSMYDAVIS
no I will check that in the morning is there any one in particular that would cause this to happen
Oct 7, 2014 at 9:07 PM
SATURNTECH9
  • 30,869 POSTS
In the fuse box on the left side of the engine compartment fuse number 116 its a 50 amp fuse it should have battery voltage to both sides of it . That fuse feeds power to the ignition switch.
Oct 7, 2014 at 9:26 PM
