When you get up to about 40 miles an hour it just quits pulling, like a neutral. You slow down or switch gears second to third and starts pulling a little, but then stops again.
My T-case is leaking a little would that cause it to slip around 40 mph?
The the little the seals leaking around the back cancel that cause a problem at 40?
Oct 18, 2018 at 7:01 PM
