I broke the wire harness wire?
2021 RAM 1500
18,450 MILES • 5.7L • V8 • 4WD • AUTOMATIC
  • 45 POSTS
I broke this wire while trying to get the spare tire down to replace a flat tire. I had several lamps on the dash, ABS, stability control, 4wd, tire pressure, cruise control etc. The broken wire was about three feet long with two metal prongs on the good end. This wire was hooked by my long metal rod I used to try to lower the spare tire. It came out with this rod when I was unable to lower the spare tire and pulled the rod back to me. The dealer replaced the right wheel speed sensor connector and repaired a section of harness. Removed and replaced bad connector, repairs of wiring and verified no DTC. The cost was $289. Do you think this was a reasonable solution to this problem?
Thanks, Jim Felland
Aug 22, 2023 at 10:18 AM
Yes, that sounds reasonable, do you have any problem with the repair?
Aug 22, 2023 at 5:06 PM
  • 45 POSTS
Thanks Ken L.,
No problem with the repair. I was just curious.
Jim Felland
Aug 23, 2023 at 10:23 AM
Use 2CarPros anytime, we are here to help. Please tell a friend.
Aug 24, 2023 at 10:52 AM
