I am getting steam from my reservoir tank.
1990 TOYOTA CAMRY
196,534 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
SHAUN F
I've checked the temp of the coolant and it isn't getting to hot. Thermostat has been replaced and checked with boiling water, rad has been flushed and burped, all hoses are in good shape with no leaks. Fans come on as they should... But I'm getting excessive steam from the reservoir tank breather hole. Any ideas would be very helpful. Thank you.
Apr 9, 2014 at 5:41 AM
HMAC300
  • 48,601 POSTS
have it checked for a head gasket leak
Apr 9, 2014 at 7:10 AM
SHAUN F
The head gasket is new. We replaced it in January. When we did the change we used an oem gasket and put a bead of "liquid" gasket in the recessed groove. How would I check that to make sure we didn't goof it up? And why would that be the reason I'm getting steam from my reservoir tank? I'm not all that mechanically inclined, so I'm just trying to understand. Thank you very much for your help.
Apr 9, 2014 at 10:46 AM
HMAC300
  • 48,601 POSTS
you aren't supposed to be putting liquid gasket in a recessed groove on a head gasket they are self sealing. and you may be getting the steam because the head gasket can be on upside down and or the head may be warped and not a flat surface.
Apr 9, 2014 at 12:46 PM
SHAUN F
Apr 10, 2014 at 3:45 AM
