Engine shut off while driving
2007 OPEL CORSA
243,064 MILES • 1.4L • 4 CYL • 2WD • MANUAL
DANIEL GENDA
I checked crank sensor, fuel pump, but still stalls. I am a beginner mechanic.
Jan 29, 2020 at 1:16 PM
This vehicle isn't offered in the US, so my technical information is limited.
You indicate it still stalls. I have a question, does it do it when you are driving or only at an idle? Also, you checked the crank sensor and fuel pump. Keep in mind, both can work one minute and not the next. So, when it stalls, does it start right back up? When it shuts down, does it feel like you turned the key off suddenly or does it act odd and then stall? Is the check engine light staying one when the engine is running? Does it happen when the engine is hot or cold?
Commonly, a crankshaft position sensor will fail when it gets hot and then work again when it starts to cool. Take a look through these two links and see if the symptoms mirror what is listed.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Also, a fuel pump can be weak and act the same way.
Let me know as much as you can as far as the questions above. I will watch for your reply
Jan 29, 2020 at 6:50 PM
