2001 Hyundai XG300 SPEED INPUT SENSOR?
2001 HYUNDAI XG300
SLIGHTLEEBALD
Engine Performance problem
2001 Hyundai XG300 6 cyl Automatic 110000 miles
jerks like like does not want to shift gears - when go up to 60 feels like it's jerking. Had the sensor replaced at about 80K miles but now having the same issue. Please advise.
Nov 29, 2009 at 12:26 PM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated The vehicle needs to be plugged into a diagnostic computer to see if there are any transmission related fault codes stored (not all generic OBDII handheld scanners will read trans codes) this sound like an internal pressure issue in the transmission rather than a speed sensor fault .. speed sensor faults generally cause the trans to shift early/late .. most good trans shops will be able to diagnose/repair the fault for you Hope this helps
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_613.png
Dec 3, 2009 at 5:11 AM
