Hyundai Verna 2000
2000 HYUNDAI VERNA
HAAM2924
  • 15 POSTS
I want figures or schematics for Hyundai Verna 2000 tablon (front ) dismantle to check the A/C switches & filter .
if it possible please send me links for service manual download becuase i want to repair this by my self
Thanks in advanced
May 15, 2013 at 1:52 AM
KHLOW2008
  • 41,814 POSTS
We do not have the Verna in our database but it seems the Accent should be similar so I can try to get the schematics for you but first of all you need to be specific which ones you want.
What is your problm and what do you want to do?
May 15, 2013 at 7:22 AM
HAAM2924
  • 15 POSTS
yes you are right verna is known as accent in other countries , please help in optaining the repair (workshop) manual
regards,,,
May 15, 2013 at 9:24 AM
KHLOW2008
  • 41,814 POSTS
The shop manual is a very large file and it is not possible for me to upload everything.
Let me know which specific system you want and I will try to get it for you, getting the whole file is out of the question. You would need to subscribe to a service provider or buy the manual yourself.
May 19, 2013 at 12:40 AM
HAAM2924
  • 15 POSTS
Thanks ,can you provide the part which show how to dismantle the tablon (the part contans tape ,ac switches,ac filter ,steering...etc
May 19, 2013 at 12:58 AM
KHLOW2008
  • 41,814 POSTS
Our database is not very specific on this and I can only come up with this. For anything further, you would need to look while you sork on it.
HEATER CONTROL PANEL
Removal & Installation
1. Disconnect negative battery cable. Disconnect connector for cigarette lighter.
Using a screwdriver, pry loose two clips and remove front console cover.
2. Pull out ashtray and remove trim panel attaching screws. Remove center fascia panel. Remove heater control panel. Disconnect electrical connections and cable clips. Remove cables from control panel. Disconnect vacuum connector from rotary knob control panels.
3. To install, reverse removal procedure. Adjust temperature control cable.
DASH PAD
1. Disable air bag system. Disconnect negative battery cable. Remove steering wheel and steering column upper and lower shrouds. Remove multifunction switch. Remove cluster fascia panel. Remove instrument cluster and disconnect
connectors.
2. Remove hood release handle screws. Remove side fascia panel and disconnect mirror controls (if equipped). Remove cassette player and radio. Remove lower center fascia assembly. Remove driver's side lower crash pad.
3. Remove left side lower instrument panel. Remove right side main lower crash
pad. Remove glove box. Remove heater control panel. Remove right and left
front speaker grilles. Remove dash pad. To install, reverse removal procedure.
May 19, 2013 at 1:55 AM
HAAM2924
  • 15 POSTS
Thanks alot,
but please if there is aschematics or figures for the steps it will help alot.
May 19, 2013 at 2:27 AM
