2006 Hyundai Tiburon Just Replaced Spindle
2006 HYUNDAI TIBURON
74,000 MILES • 4 CYL • FWD • AUTOMATIC
82EDWARDS
I just finished replacing the spindle, wheel bearing, hub and roter on my girlfriends tiburon. She hit a pot hole and almost rolled her car. This busted the wheel bearing and since she did not tell me it also caused damage to the spindle and hub. Now that I have it all back together, the engine reves up and there is a pause before the tires start to spin. Then the tires start to spin, but in a few seconds the tires will stop spinning again while the engine is still reved.
Any ideas?
Feb 3, 2010 at 10:03 PM
BMRFIXIT
  • 19,053 POSTS
Check and make sure that the axle back in the tranny
as it is possible that came out of the tranny side
Feb 3, 2010 at 10:50 PM
82EDWARDS
The axle still appears to be in the tranny. With the drive shaft nut off, there is a slight give when I pull or push on the axle. It will not come out, and it does not go in and stay in when I push in on it. Should I wack it with a hammer or something? is it possible that either of the joints are out of alignment?
Feb 4, 2010 at 9:31 AM
BMRFIXIT
  • 19,053 POSTS
Small tap should be OK
also if axle is broken will act the same way too
or if was pulled out of place
Feb 4, 2010 at 9:31 PM
