2004 Hyundai Tiburon hub assembly replacement question
2004 HYUNDAI TIBURON
130,000 MILES • 6 CYL • FWD • AUTOMATIC
JLAIOLA
  • 8 POSTS
good afternoon, I'm terribly to sorry to bother you as i know your busy.
my question is that i just replaced my passenger rear hub assembly and the entire wheel still has wobbling play in it, as the components are tight and I'm just wanting to find out what mistake i made.
once again thank you for your time.
Aug 17, 2009 at 3:21 AM
2CARPRO JACK
  • 11,533 POSTS
Is the wheel bent? If you replaced the hub assembly it should spin true if the rim is ok.
Aug 17, 2009 at 11:03 AM
JLAIOLA
  • 8 POSTS
the wheel seems to be in good condition, although not perfect, the good part is that the winding noise has stopped, but even after i put the new hub assembly on the entire wheel has about a quarter inch or more of play in it, and i was wondering if maybe i could put another (spacer washer) on the nuckle to stop it from haveing the play in it,
Aug 18, 2009 at 4:13 AM
JLAIOLA
  • 8 POSTS
i was also wondering if its better to use a neumatic gun for tightening the hub nut instead of wrenching it on there by hand, because this particular model does not come with a cotter pin
Aug 18, 2009 at 4:15 AM
2CARPRO JACK
  • 11,533 POSTS
If it has that much play in it, there is either something wrong or the nut isnt tight/seated. I cant find the torque spec for that nut, how tight did you torque it down? I would use hand tools to tighten it up, so you get afeel for how tight it is. Look at the suspension to be sure it isnt something else causing the play like a bad bushing
Aug 18, 2009 at 7:42 AM
JLAIOLA
  • 8 POSTS
i torqued it at about 80
but thank you i didnt think about the bushing,
do you think by adding an extra spacer washer in the hub before the nut gets on, that it might be a tighter fit?
once again i really appreciate your time
Aug 19, 2009 at 1:51 AM
2CARPRO JACK
  • 11,533 POSTS
My pleasure, If the freeplay isnt correct when the nut is tightened, there is another issue.from what I can see in Mitchell that is a sealed bearing hub unit, once the nut is correctly torqued the pre-load should be good.If you can make it good with a washer, go for it, but I recommend finding out what is wrong and fixing it.
Aug 19, 2009 at 7:45 AM
JLAIOLA
  • 8 POSTS
great i i'll go for it
my newest addition for the retry
is i went ahead and got ahold of another nut that is the same thread and slightly larger in girth, im going to make a new attempt on this tomorrow and hopefully it should be okay but i cant thank you enough for your help. this is a great website you operate.
Aug 22, 2009 at 3:17 AM
2CARPRO JACK
  • 11,533 POSTS
Glad to be of assistance, and thank you.
Aug 22, 2009 at 8:27 AM
JLAIOLA
  • 8 POSTS
i have to tell you im very impressed with your website its very instructional, i currently work in a small repair shop and usually do the basics for auto and diesel repair, but my main question was i was considering going back to school to possibly get a master certification out of the business, do you have a recommendations as to what schools would be good to attend?
Aug 23, 2009 at 2:16 AM
2CARPRO JACK
  • 11,533 POSTS
I would do research online.If you are looking to get a Master ASE Cert. you should go to their website to see what exactly they offer, the classes would be geared toward their program.Most things you learn in class will teach you principles of things and diagnostic skills, but honestly real world experience in the most valuable, and necessary to get a Master cert
Aug 23, 2009 at 11:46 AM
JLAIOLA
  • 8 POSTS
that sounds great, i believe your right, because im one of those older guys who actually got a job in the field doing the work and learning the trade years ago as aposed to schooling, and i felt the experience was a lot more valuable than what i've heard about in the schooling aspect. but i would like to learn about hybrid technology more and be able to condition my self for todays job market and im also trying to get out of california and find a job elswhere, if you have a recommendations, that would be wonderfull.
Aug 24, 2009 at 3:01 AM
2CARPRO JACK
  • 11,533 POSTS
Look for accredited schools where you are willing to live.Wyoming Tech is a good school, there are many others as well.Try a Google search for Hybrid tech schools and go from there.
Aug 24, 2009 at 7:44 AM
