2003 Hyundai Tiburon Clutch Slip
2003 HYUNDAI TIBURON
71,000 MILES • 6 CYL • 2WD • MANUAL
OSGA
I have just had my clutch and flywheel replaced on my car and now under heavy excelaration i get clutch slip.
What could be the cause of this ?
Jun 11, 2010 at 6:57 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
These are a pull type clutch, so i would be thinking that the only way it could slip is that the work shop did not torque down the clutch pressure plate correctly, take it back to the work shop that did the job, this is there responsibility to check there work is correct first.
mark (mhpautos)
Jun 11, 2010 at 7:19 AM
OSGA
[quote:2c28f9d8f8="mhpautos"]Hi there,
mark (mhpautos)[/quote:2c28f9d8f8]
Thanks for the reply Mark.
The workshop told me that it was due to crud in the fluid an that i need a new slave cylinder, does this sound right ?
Thanks Sergio
Jun 11, 2010 at 7:59 AM
MHPAUTOS
  • 31,937 POSTS
If the slave cylinder was so bad, why was it not replaced in the first place, if it was sticking on, in theory this could be the cause, buy in over 35 years in the industry, i have never seen this as they have described, but there is always a first time .... maybe.....
mark (mhpautos)
Jun 11, 2010 at 9:57 AM
