2003 Hyundai Tiburon Clutch removal steps
2003 HYUNDAI TIBURON
82,000 MILES • 6 CYL • FWD • MANUAL
RDASTRUP
I am replacing a clutch on a 03 Hyundai 2.7 liter V6 Tiburon and I am having problems with getting access to the clutch, in the pics you will see that there is a bell housing that mounts to the engine then the gear box is mounted to the bell housing, the bell housing is one piece and I can't access the clutch plate to unbolt it from the flywheel, I have unbolted the bell housing from the engine were the clutch is located and seperate it from the engine to access the clutch, but it won''t seperate from the engine, I can't access the bolts on the clutch plate to unbolt it from the flywheel, how do you seperate the clutch system from the flywheel, is there a speical tool that is needed to seperate the two from each other in order to access the clutch. As you can see in the pics I am at a stand still, I have look online in books and all the information that they give me is the steps on how to replace the clutch, not how to get to and access the clutch , so if you can help me it would be much graditude and thanks on your part.
Apr 10, 2009 at 11:41 AM
KHLOW2008
  • 41,814 POSTS
Hi rdastrup,
Thank you for the donation.
Did you disconnect the clutch fork completely? There is a 14 mm nut that has to be removed failing which the trans cannot be completely disengaged from engine.
Let me know if it helps.
Apr 10, 2009 at 5:41 PM
MILNE
  • 5 POSTS
i removed the nut and it came right out thank yu.
Jun 6, 2012 at 1:00 AM
RIVERMIKERAT
  • 6,110 POSTS
milne: Thank you for letting us know our response helped.
Closing thread.
Jul 28, 2012 at 6:27 PM
BABY44
What if you have even got the clutch out but you can not actually get the transmision to come out to have room to put the new clutch in . He can not get the space to put the new clutch in without removal of the transmison but he can not get the transmision to come out to put the new clutch in? Help please b4 I strangle someone.
Apr 25, 2016 at 11:25 AM
