2002 Hyundai Tiburon
2002 HYUNDAI TIBURON
112,000 MILES • V8 • FWD • MANUAL
TOM BOLZAN
my driver side directional signal light is stuck on, even when the car is o9ff. The dealer did not look/find a short in any of the wires/curcuit and jumped directly to the conclusion that the main curcuit box(IMA? $800 part) would need to be replaced
Any possible alternatice solutions
Jan 10, 2010 at 8:51 PM
The interesting thing is the flasher should only work when the ignition is on. When it is off, it shouldn't work at all. They may be correct. The only thing I can suggest is to check in the power distribution box under the hood and check to see if you model has a relay for the signals. Remove it and swith it with a different one with the same part number to see if that makes a difference.
Let me know what you find.
May 24, 2010 at 10:21 PM
