clutch replacement instructions
2001 HYUNDAI TIBURON
152,000 MILES • 4 CYL • 2WD • MANUAL
NIKILJ
I can't get my clutch to engage and let me go into gear. I tried adding clutch fluid it didn't fix anything. I don't know what is wrong with it.
Dec 20, 2009 at 5:11 PM
This is due to the slave cylinder leaking most likely and not releasing the clutch.
Here is a guide that will talk about this:
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Also, here is a guide on how to replace the throw out bearing that covers most everything you will need:
https://www.2carpros.com/articles/throw-out-bearing-replacement
Lastly here is the process from the manual that will show you what you need to do to replace it. Let us know what questions you have.
Thanks.
Dec 3, 2020 at 7:56 PM
