Stalls while driving. Fuel issue? Exhaust restriction?
2001 HYUNDAI TIBURON
75,857 MILES • 4 CYL • 2WD • MANUAL
KCAMRAC
Helllo,
I am having issues with my car almost stalling when my RPM range gets between 3000 and 4000 rpms.. I feel it most when taking off in 1st gear or driving in 2nd gear. The drop is a violent "almost" stallout. When I pull up to traffic lights, the rpms dip to an almost stall, or the car completely stalls.. If I'm driving at highway speeds, I can get it to almost die by stomping on the gas pedal. It's almost like my car is choking to death. I have NO check engine light. I am positive that it works. I have already changed the fuel pump, fuel filter, plugs and wires. What else could possible be wrong? I am desperate for help..
Thank you....
Jul 6, 2009 at 9:22 PM
This does sound like a fuel issue but if you changed the pump then we can assume that is okay. However, here is a guide that will help with this issue in more general terms. It will get us started on this issue.
https://www.2carpros.com/articles/engine-stalls
I would suggest we check the fuel pressure just to be sure it is okay.
Lastly this could be a restricted exhaust so we need to test the converter and find out if it is plugged.
Below you will find the process on how to replace the converter as I suspect this is the issue.
Once we run through all this stuff we will have a better idea what the issue is. Please let us know what you find with this and we can go from there. Thanks
Jul 14, 2021 at 8:22 PM
