2000 Hyundai Tiburon spark plugs
2000 HYUNDAI TIBURON
CHRISTINEKERSHAW
Electrical problem
2000 Hyundai Tiburon 4 cyl Two Wheel Drive Automatic
can bad spark plugs make car stall and start back up and then never start again or would that b feul pump
Sep 23, 2010 at 10:28 AM
Do below to determine if its fuel or spark issue
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Sep 23, 2010 at 10:36 PM
