hyundai starex wont start after replacing the transmission
2010 HYUNDAI STAREX
WENGWENG
my hyundai starex wont start after we replace the transmission with a new one, the dashboard has light when you turn the ignition key but it wont crank. can you help me with this? thank you
Feb 5, 2014 at 9:38 PM
HMAC300
  • 48,601 POSTS
see If you blew a fuse in fuse box under hood ign 2 we don't have that vehicle in U.s. also if you disconnected battery try resetting your anti theft look online if you don'thave a manual.
Feb 6, 2014 at 8:18 AM
HYUNDAI USER
  • 5 POSTS
A mechanic alleged that the fuel pump was grounded. However, after changing the fuel pump, it cranks but will not start.
We have checked the line going to the injector for presence of fuel, and there was fuel, but I noticed that the pressure is not strong.
The mechanic cleaned the crankcase sensor, but yet, it will not start.
Jul 7, 2019 at 2:38 PM (Merged)
It sounds like the fuel pump is not working correctly. did he use an OEM replacement? Will the engine run on starting fluid? Also we should run the codes to see what comes up. here are two guides to help get us started:
and
HYUNDAI USER
  • 5 POSTS
Ken,
Thank you very much for your very meaningful, well explained and complete provision of helpful guides and information. Yesterday, I sought the assistance of a duly licensed mechanic and assisted by a (computer box/ECU) technician which used two (2) kinds of instruments separately (probably an OBD II Scanner and the other is an OBD II programmable scanner).
The problem which they relayed was that:
1. In turning the key to "ON" position, the "Check Engine" warning should flash momentarily and goes out in few seconds. In my car's case, the "Check Engine" emblem does not show up.
2. After doing several procedures, they claimed that there is power going into the ECU, but no power is coming out, hence, no signal or code could be retrieved. They explained that because of the "absence of power coming out of the ECU, all the systems of the car will not function.
These lead them to the idea that the problem might be the computer box, itself. They detached the ECU, checked for any burnt portions or parts but found nothing though.
I am very hopeful to receive more of your very enlightening ideas.
Thank you very much and more power!
If power is going in but not coming out the ECU as bad and needs to be replaced. Please let us know what you find. We are interested to see what it is.
HYUNDAI USER
  • 5 POSTS
Sir Ken,
Yes Sir. I will inform you, as soon as the mechanic and the technician come back and make final evaluation.
Jul 7, 2019 at 2:39 PM (Merged)
HYUNDAI USER
  • 5 POSTS
Sir:
May I give you this information which may be helpful to you in the future. The first mechanic/driver (who lacks proper knowledge, i suppose) who installed the fuel pump (original, with seal and sticker bought from an authorized dealer) tested the injectors' power supply using a test light directly connected to the 12V battery,
According to the mechanic and the technician, the power might have crept upwards to the ECU, supplying over voltage (12V or maybe higher since I steadily use a voltmeter in my car and it always register 13+ volts) and causing some of its minute parts to bust, hence, corrupting the entire ECU unit.
MHIJAZI85
Dear sir
ihave problem in my bus I remove the deisel injection and make clean for the intercooler and I start the engine a it's okay no have any problem after that by 2 hours I have problem in the engine black smoke and nose voice and I remove the injection again after that the bus don't start
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
Black smoke means there's too much or unburned fuel most commonly caused by a dirty air filter. Injectors stuck open dumping to much fuel also causes this
Yes, that is true. too many voltage due to a faulty alternator will cause this issue. Let me know what happens.
HYUNDAI USER
  • 5 POSTS
Sir:
It was proven. The ECU was really defective. After final evaluation by the ECU technician, he directed me to buy a new ECU. Luckily, one item bearing the same Part Number was available at a local dealer here (Philippines) although the same was not a genuine part but a replacement (Mobis, made in Korea).
After installation, just a single crack made the engine running continuously which means, that the original (old) ECU was not really working.
However, theCheck Engine sign is blinking, which, according to the technician, it requires me to bring the car to a Hyubdai Service Center in order to reprogram the Vehicle Identification/Information and the blinking sign will be automatically resolved.
I hope everything will be resolved soon. Thank you for your useful and informative ideas. More power!
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
KLIU
Our Hyundai Starex, (actually Jac Refine, it was bought in Beijing) has been having trouble since summer 2008 with occasionally not starting when warm. It needs to be driven for a bit, then try to start it within about 30 min. of stopping. In the past it only did this in summer, but I've had trouble several times this winter. I don't speak Chinese so I haven't been handling the repairs--I know several things have been tried and seem to make a difference for awhile, but then it begins again. I'm getting tired of being told to just take my chances, nothing can be done. At a minimum, I would like info if this is likely to ever leave me completely stranded--neither 25 degrees or 95 degrees would be fun to get stuck.
RIVERMIKERAT
  • 6,110 POSTS
Check fuel pressure when the problem is occurring. It sounds like it may be either vapor lock or a weak fuel pump.
