Ken,
Thank you very much for your very meaningful, well explained and complete provision of helpful guides and information. Yesterday, I sought the assistance of a duly licensed mechanic and assisted by a (computer box/ECU) technician which used two (2) kinds of instruments separately (probably an OBD II Scanner and the other is an OBD II programmable scanner).
The problem which they relayed was that:
1. In turning the key to "ON" position, the "Check Engine" warning should flash momentarily and goes out in few seconds. In my car's case, the "Check Engine" emblem does not show up.
2. After doing several procedures, they claimed that there is power going into the ECU, but no power is coming out, hence, no signal or code could be retrieved. They explained that because of the "absence of power coming out of the ECU, all the systems of the car will not function.
These lead them to the idea that the problem might be the computer box, itself. They detached the ECU, checked for any burnt portions or parts but found nothing though.
I am very hopeful to receive more of your very enlightening ideas.
Thank you very much and more power!
Jul 7, 2019 at 2:38 PM
(Merged)
