The car suddenly stopped running and all dashboard lights ceased all. Only the radio was still working. There were no noticeable noises from the engine. I tried to start it, and it would not turn over. But there were no abnormal noises from the engine when I was attempting to start it. The tow truck driver thought that the fuel pump had stopped working based on the normal noises at startup. The mechanic told me it was probably the crank shaft position sensor. Then he called back to recommend replacing the timing belt due to age and 2-3 missing notches in various spots on the belt. The next day, after the new timing belt was installed, the mechanic said that the original problem was caused by the timing belt slipping and that I would need a new engine due to the damage to the valves and pistons. Would I have heard strange noises from the engine when I initially tried to start it after it stalled? I'm wondering if the mechanic installed the new belt incorrectly and is covering up that fact. I made a surprise visit to the garage tonight to pickup a few items and the mechanic was not there. I looked under the hood and the new timing belt was no longer installed. However, when I called the mechanic earlier in the day, he stated that I would have to pay for the new timing belt and sensor that was installed. Something is not adding up. Are there any questions that I can ask the mechanic in regards to installing the new timing belt? Are reports printed out to prove that it was installed correctly? Please help!
Jun 30, 2009 at 7:03 PM
