Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Hyundai
Sonata
Body
Gas Door
Where is the fuse for the fuel door
2004 HYUNDAI SONATA
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
TGAR847
MEMBER
1 POST
FOLLOW
It quit opening and the manual was not helpful. The wife has to open the trunk when she gets fuel.
Jul 1, 2010 at 3:28 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
Check fuse # 8 (15 amp) in the passenger compartment junction block. This fuse protects the fuel filler door and the trunk lid switch circuits.
If the fuse is okay check for power through the switch. Here is a guide and the fuel door wiring diagram to show you how.
Check out the diagrams (below).
Cheers
Image (Click to enlarge)
Jul 1, 2010 at 6:34 PM
ENESHAD
MEMBER
1 POST
I had this problem with my car. It was the switch that was bad.
May 2, 2018 at 12:01 PM
ADALLEN52
MEMBER
how do i replace the fuel filler door?
Jul 14, 2020 at 10:56 AM (Merged)
CERTIFIED EXPERT
I attached the process on how to replace the actual door. You actually remove the insert and the door and hinge comes with it.
Let us know if you have more questions. Thanks
ADALLEN52
MEMBER
I am talking about the door you open to get to the fuel cap?
ADALLEN52
MEMBER
thank you.
CERTIFIED EXPERT
You are welcome. Please come back to 2CarPros next time. Thanks
