2003 Hyundai Sonata Squeak/squeal noise
2003 HYUNDAI SONATA
80,000 MILES • 4 CYL • FWD • AUTOMATIC
NINNYKID
I had the belts replaced in July 07. The belts started making a noise about a week, to week and a half later. They were not doing it all the time, just mainly when the A/C was turned on. I returned to my mechanic and he tightened them, and the noise subsided temporarily. I have had 4 different sets of Gates belts put on there since, and continue to have a problem. The noise now is pretty constant and gets louder when accelerator is engaged. It was suggested to me that the alternator could possibly be going bad, and that the noise was coming from it. Do you think that this could be the case?
Feb 6, 2008 at 3:41 PM
BRIAN DE VRIES
Hello sir,
My father in law has the same kind of problem, with the same car Hyundai Sonata 2.0 2003.
The mechanics can't find the problem.
Did you allready have the problem fixed?
And if so, what was the problem?
Greetings,
Brian
The Netherlands
Mar 30, 2011 at 3:29 PM
NINNYKID
The problem was the replacement belts that had been installed. The mechanic had to get the belts from Hyundai, and once he installed those it corrected the problem. Good luck.
Mar 31, 2011 at 1:14 PM
