Hi Richard,
Starting is affected by the following :
Check Crankshaft Position (CKP) Sensor Operation
Check Ignition Spark
Check Fuel Supply
Check ECM Harness Connectors
Check Sensors
• Engine Coolant Temperature (ECT) sensor.
• Manifold Absolute Pressure/Intake Air Temperature (MAP/IAT) sensor.
• Throttle Position (TP) sensor.
• Mass Airflow (MAF) sensor.
• Fuel injector signal circuit.
Check Ignition Timing
Check For Vacuum Leaks
© 2008 Mitchell Repair Information Co., LLC.
Since pressing the accelerator pedal allows easier starting, the items directly related would be
1. TP Sensor.
2. MAF Sensor
3. MAP/IAT sensor.
Oct 1, 2009 at 11:39 AM
