Hello-
It appears that you need to replace your belt tensioner. I have attached that for you. Ensure you adjust as required.
[For 2.4 L DOHC ENGINE]
[For 2.7L SOHC ENGINE]
The drive tension is adjusted automatically by the autotensioner.
NOTE: The belt tension must be measured between the specified pulleys. When a new belt is installed, adjust the tension to the center of the standard range indicated under "New." Let the engine idle for 5 minutes or more, and check the standard value indicated under "Inspection." When adjusting a used belt or a newly installed belt after 5 minutes or more of operation, refer to the standard value indicated under "Used." Refer to the standard value indicated under inspection for periodic inspections.
ADJUSTMENT
2.4L DOHC ENGINE]
Loosen the tension pulley fixing bolt A.
Adjust the belt deflection with adjustment bolt B.
Tighten the fixing bolt A.
Re-check the belt deflection and re-adjust, if necessary. NOTE: Before re-checking, crank the engine one or more revolutions.
[2.7L SOHC ENGINE]
If the mean indicator is positioned over the max. position, replace the drive belt.
When replacing the drive belt, the mean indicator position must be between min. position and max. position.
Nov 7, 2008 at 10:03 PM
