2002 Hyundai Sonata cv axle
2002 HYUNDAI SONATA
LITTLEMARV
Drive Train Axles Bearings problem
2002 Hyundai Sonata 4 cyl Front Wheel Drive Automatic
how does it come out of transmission side
Jun 25, 2009 at 8:30 PM
BMRFIXIT
  • 19,053 POSTS
Insert a pry bar between the transaxle case and the axle shaft, and pry the axle shaft from the transaxle NOTE:Do not pull on the axle shaft, doing so will damage the double offset joint Be sure to use the pry bar. Do not insert the pry bar deeply enough to damage the oil seal.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_402.jpg
Jul 1, 2009 at 7:44 PM
