2002 Hyundai Sonata Airbag light stays on after startup
2002 HYUNDAI SONATA
92,000 MILES • 4 CYL • FWD • AUTOMATIC
CIVICFAN85
In my 02 sonata the airbag light stays on continuously after the car is started. I assume it does its self test because for a second the light goes off when i start the car but afterwards remains on until i shut the car off. Should i be worried about it? I thought maybe a wire or something was faulty.
Mar 17, 2008 at 1:54 AM
AL206
I have an 02 sonata with the same problem. Did you get your issue resolved? I talked to one guy who said 9 times out of 10 it's corrected by reseating the pins under the seats. I tried that, but the light is still on. I have an appointment to have it checked out on Monday. Let me know if your problem was resolved and I'll try to remember to post an update after I find out on Monday.
Mar 28, 2008 at 3:07 PM
ULTEEM8
Did you ever get the air bag light checked out? If so please give us an update..
thanks
May 17, 2008 at 10:48 AM
SOUPP_X
I have the same problem. I had a Tech look at it an dit pulled a code of B1378 . He said it was either the side airbag on the drivers side or the Control Module. I am doing a few checks myself he showed me how to do to see which one it is. Do any of you have a plug hanging under your drivers seat that is not hooked up? It has a blaco connector and 2 wires coming from it (one Black and one Red)?
May 17, 2008 at 1:00 PM
