Pop your trunk. Remove the carpeting on the driver side. You may have to remove some plastic retaining clips to do so. You will see the antenna attached to a bracket, held by 2 or maybe 3 10mm screws. Need to detach the electrical connector, antenna wire extension and a ground wire to the body.
From outside, remove the nut that holds the antenna. I don't remember the size, an adjustable wrench works just fine.
When installing the new one, be sure to pay attention to fuel door release cable.
Nov 1, 2008 at 2:39 AM
