2000 Hyundai Sonata door panel
2000 HYUNDAI SONATA
78,888 MILES • 6 CYL • 2WD • AUTOMATIC
SALVAGE2
Does any one know if there is aspecial way to take off the passenger door panel ????
Jan 6, 2008 at 6:06 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
remove door fixtures, arm rest, window winder if fitted etc and the trim is held on the door by plastic clips, carefully pull bottom edge of trim away from door, the clips will start to pop out, you may find that some will remain in the door, the trim is a cheap cardboard so go carefully.
Mark (mhpautos)
Jan 7, 2008 at 2:49 AM
