Engine Mechanical problem
1995 Hyundai Sonata 4 cyl Front Wheel Drive Automatic
i was wondering if any other block could be made to fit a 95 hyundai sonata 2.0 dohc engine mine is automatic and the timing belt broke and dropped 2 valves and busted 2 pistons i have been told an older eagle talon block are plymouth laser block would fit but other have said only a 95 hyundai sonata block will fit the blocks on a older eclipse 2.0 dohc cam look like they would work any help would be great thanks
Mar 27, 2009 at 3:32 PM
