Hi,Look For A Rubber Plug In the Front Of the rotor.Take out this plug with a screwdriver,Shine a light in the hole Where the plug was removed,turn the rotor till you see the adjuster wheel,use a screwdriver and turn this adjuster,till you see no threads on the adjuster.now remove the rotor.you may have to hit the rotor carefully ,on the flange, try not to hit the wheel studs. what happens is rust builds up inside there,stopping the shoes from coming off.if you don't see a plug in the front of the rotor ,then look behind it, for a rubber plug ,could be round or oval.also use crc to soak around the rotor flange.
Hope This Helps You,
Good Luck
Edward S.
Mar 2, 2021 at 8:50 AM
(Merged)
