2005 Hyundai Santa Fe sputters off and on
2005 HYUNDAI SANTA FE
75,000 MILES • 6 CYL • 4WD • AUTOMATIC
BENTHERE01
Suddenly started cutting in and out at times. When running, the tach will stop working and it will start cutting out especially when the rpms are low like at gear changes. If I keep the rpms up, it won't do it much at all. When I first start each morning it runs fine for a couple of minutes. Started this about a week ago with no notice and have had no problems before. Have had 3 places put it on the computer as the "check engine" light is on and it says it is misfiring and it will be running smooth at the time. They also say the codes it puts out are not consistant with any they have seen. One says it sounds like a cranksaft sensor. Everyone else just says they will start going through it.
Jan 27, 2010 at 2:15 PM
Does it get worse when climbing a hill or under a heavy load? If so, have them check the fuel pump pressure. If not, it sounds like the one mechanic may be right, crank sensor.
Feb 6, 2010 at 9:27 PM
BENTHERE01
Pulling anything or going up hill does not make a difference. I have been told now the timeing belt pully is bad and if that is not it it could be a CO2 sensor if not the crank sensor.
Feb 7, 2010 at 10:56 AM
MCZTR
hi benthere01,
how did you end up solving your problem?
my car is giving me the same problem
Nov 27, 2010 at 2:04 PM
The O2 sensor would set the check engine light. The crank sensor could be the issue. However, a bad timing belt would be all the time.
Nov 28, 2010 at 3:33 AM
