2003 Hyundai Santa Fe washer
2003 HYUNDAI SANTA FE
51,000 MILES • 4 CYL • FWD • AUTOMATIC
KYLEMATT
my windshield washer pump/motor does not seem to be working. i dont hear anything when i hit switch. full tank. not frozen. wipers work.
hard to change?
Feb 10, 2009 at 7:58 AM
Hi:
Using a volt meter, check to see if you get 12 volts to the washer motor when the button is pushed. If you do, replace the motor. If not, trace the wiring back to the switch to check for loos connections, damaged wiring...
Let me know what you find.
Feb 24, 2009 at 10:34 AM
