about the crank shaft sensor, they can fail and give a FALSE READING and since it doesnt show that its faulty and giving no reference the computer will still use the false signal and fire at wrong times!
the fuel pump energizes when the key is turned to the on position to power up and prime up the fuel system so it will start.
when the key is turned to the start position and a ignition signal or pulse if you will, is recieved via the crank or cam sensor then the pump turns on again and the injectors fire, and hopefully the veihcle starts.
with the code he has which is cam sensor issue. as it is, it may be that the pump isnt getting that command to turn back on, or maybe it doesnt want turn on when itstold to causing that initial bit of fuel that was provided to be burned up, and the engine die at the same time because of the same amount of fuel.
im thinking disabling all the other sensors may be working becaus without the MAF sensor hooked up the engine is commanding less FUEL due to less air and that causes it to run for 3 seconds more?
correct me if im wrong.
so itsallgood, that is my theory or what is wrong.
and if you can check out what i listed about the cam sensor and crank sensor in my previous post, and reply back to me, hopefully tellign me the problem is fixed.
ill be waiting.
and with the argument between me and mr airsoftsold, i suppose you can say were a few mechanics with different oppinions, and i guess now you have more things to check.
Jun 24, 2008 at 8:21 AM
