2002 Hyundai Santa Fe Oil leak
2002 HYUNDAI SANTA FE
99,652 MILES • 4 CYL • 2WD • MANUAL
JOETWOS
Hi
I'm new to the forum, not an expert neither a pro, I'm just someone looking for a little help. My problem is that my Santi is leaking oil and I could not find from where.
I had clean the motor, there's no leaking from the top of it. Took the crank cover out, because it was oil on it, clean it and check for any cracks, no cracks were found. The car stills leaking oil and I don't know what esle to do.
I had took the car to an expert and cost me $45.00 just to put some marinetex to the crank cover borders. Please help!
Thanks,
joetwos
Jul 5, 2008 at 11:28 AM
SERVICE WRITER
  • 9,123 POSTS
There are a couple of things to consider. First check the pcv valve and make sure there is suction to it. You can buy some dye that can be added to the oil and then checked for the source. Using good lighting and dental mirrors carefully look for the source. You may need to remove things as you go along. Posting pics may help if you run into a problem or question.
Jul 5, 2008 at 11:35 AM
JOETWOS
I had found the leak. It seems I need to replace the crank cover. No matter how much I thighten the screw, the leak continues from the top of the cover. I'm trying to find a new one or one in excellent condition but had no luck. Can you help me with the name of the part. I'm looking using the name: "crank cover".
Thanks,
Jul 5, 2008 at 3:00 PM
SERVICE WRITER
  • 9,123 POSTS
Post a picture so I can see what you mean.
Jul 5, 2008 at 8:17 PM
KHLOW2008
  • 41,814 POSTS
Hi joetwos.
Are you sure it is not the oil seals?
Jul 5, 2008 at 10:44 PM
