2002 Hyundai Santa Fe am radio noise
2002 HYUNDAI SANTA FE
63,000 MILES • 6 CYL • 4WD • AUTOMATIC
KIMARTIN
If I turn the am radio on when the engine is off the
stations come in fine. When I turn the engine on
the stations are distorted by the engine sound. Do I buy a filter or is there another solution?
Jul 8, 2008 at 11:36 AM
KHLOW2008
  • 41,814 POSTS
Hi kimartin,
A filter is the easiest solution.
I would check for poor grounds on all the main points to see if it helps.
If the problem starts after you replaced the spark plugs, then you might have used those without radio interference suppressors.
Jul 12, 2008 at 9:00 AM
