rough idle
HYUNDAI
MIKE LEWIS
my 2002 hyundai elantra gt runs rough at idle. code scanner said #3 cylinder has a misfire .Replaced pugs,wires,oxygen sensor,air filter,and cleaned throottle body.what could be the problem?
It has at,4cylinder,68000 miles,abs,ps,pb,pw.
Mar 17, 2007 at 11:01 AM
KIN CHAN
  • 453 POSTS
according to definition of misfire defines as an unacceptable % of incomplete combustion...lean,rich,density misfire ?...mechanical problems? ..bad ignition cpts? ..bad ignition signal to the ECM?...bad fuel injectors?..unmetered air ?? ...need more info or need a real mechanic to figure it out... trying by swap parts and hit the target is very low percentage shot on cars thats 2000 and newer ...good luck man
Mar 17, 2007 at 1:27 PM
