no Fire
HYUNDAI
TOOPAY
Just brough this car and it had been sitting up for a while so this is what has been done
change valve cover gaskets, fuel filter, spark plugs, and put in fuel treatment, did compression test, repaired several stuck valves, removed and cleaned all fuel injectors, road test and it ran good now not getting fire on #1 and #4 cyl. Help.
Apr 27, 2007 at 8:19 AM
BRUCE HUNT
  • 3,754 POSTS
Try taking a wire from a working cylinder and seeing if there is spark. It could be a wire. Didn't know the age of the car so I assume it has a distributor.
May 1, 2007 at 7:32 AM
TOOPAY
Hey thanks for the answer.
But I pulled the fuel filter and it was full of water, so I drop the tank and drain all the bad gas and water from the tank, changed the filter on the fuel pump clean the float and change the check valve. Put in some Heet to take care of the little moister left and put in some injector cleaner. The car is running but shaking bad, guess I will have to run a tank before she smooths out.
Any thoughts or suggestions.
By the way its a 97 Sonata Gl 2.0
May 1, 2007 at 9:33 PM
