hazard lights turn on when i use the turn signal
HYUNDAI
PHILLYGURL12
2001 Hyundai Tiburon 48,000 2.0L engine. I installed clear corner signal lights on Saturday. All I changed was the light bas then I just connected the lights. The battery was disconnected while doing this. While driving home on Sunday I had the AC on and I also had the the switch on to keep using the air over and over then I noticed that both the AC light & the recycle air light began flashing like hazard lights. The next day (Monday) I noticed while using my turn signal either to the left or the right both turn signal lights turn on, like if I were to put on the hazard lights. But I did notice that when using the turn signal for the left both light up but the right is lightly showing up on the dash, vice versa. I also have winshiled washer lights & they too are blinking like hazard lights when I use the turn signal. SO I have the windshield washer lights, the 2 lights for the ac and the turn signal lights blinking when using the turn signal for either left or right. Also I noticed today when I turn on the lights as if I were driving at night both turn signal lights stay on throughout the drive inside the dash and it is at this time that they do no work to the left or the right. I checked all fuses that correspond to the lights but they are all ok. I also disconnected both turn signal lights to see if one was causing the problem, nothing their either. It has to be a short somewhere but could it be the clear corners if all I did was unconnecting & connecting to the same connection. The only thing that changed was the light bulbs. (I used the ones that were shipped with it) I hope you can help me with this ir give me an idea of where to start looking. Thank You in advance.
May 7, 2007 at 6:12 PM
TURBOTUFF20G
  • 98 POSTS
try disconnecting the clear corner bulbs
May 27, 2007 at 7:36 PM
