What kind of car do you have? If it's a Hyundai then there are no adjustment points for the cable.These cars have a self adjuster in the rear brakes. Only thing I can suggest is to remove the rear drums and manually adjust the shoes as needed.Adjust the shoes out until you feel a drag on the drum.Replace the drum and try the hand brake before replacing the tire, you save time this way in case more adjusting is needed.
Apr 4, 2009 at 10:13 AM
