engine misfire
HYUNDAI
KEVIN D.
1997 Hyundai Elantra 1.8L engine
engine code P1124 TPS out of self test range
all cyl. misfire what to do to fix the problem?
what is TPS? easy to fix? cost?
Nov 3, 2007 at 10:51 AM
BLACKOP555
  • 10,386 POSTS
TPS is the Throttle Position Sensor. it sits on the bottom of the Throttle Body and it detects the position the butterfly valves are in and sends a signal to the PCM. To fix it all you have to do is take off the air intake hoses take off the throttle body and mark and remove the tps.
Nov 3, 2007 at 2:49 PM
