Add/Check Transmission Fluid on 1994 Excel?
1994 HYUNDAI
PWDIAZ
Dear Experts,
For the life of me I can't find the dipstick to check the transmission fluid on my 1994 Hyundai Excel. If anyone can help: I have a 1994 Hyundai Excel with an automatic transmission(not sure of the engine size but it's not real big). I suspect there is a problem with the transmission as the car is making a ticking sound that increases or decreases in frequency as I drive. The sound is not present when I put the tranny in neutral and rev the engine. I may need to add fluid but I can't find where I'm supposed to check or add it. The car lurches when it is under a load (like going uphill) and I floor it or turn off the overdrive to get some torque. I recently (two weeks ago) had the car serviced. One of the items on the service list was to drain and replace the tranny fluid. I noticed a the problem yesteday. I pulled of the road and looked under the hood. It looked like there was a small puddle of oil (brownish) on top of the housing of the torque converter. Anyway, the car has 98,000 miles on it. If anyone can help or tell me what the remedy is for that loud ticking sound, I'd appreciate it.
Nov 15, 2007 at 12:02 AM
The trans fill / check should be on the driver's side of the engine. As far as the ticking, that sound is usually related to the noise a lifter makes in the engine. Make sure the oil is full. And, trans fluid is red. The brown fluid may be a leak from the valve cover gasket.
Mar 25, 2009 at 12:33 PM
