2005 Other Hyundai Models Engine stopped suddenly and does n
2005 HYUNDAI
95,000 MILES • 4 CYL • 2WD • MANUAL
THABANZO
ngine stopped suddenly and does not start anymore the starter just turns
Feb 11, 2008 at 6:43 AM
MERLIN2021
  • 17,250 POSTS
Well...it looks like you have 5000 miles left on the Hyundai powertrain warrantee? Other than using that, you need to figure out what's missing, spark, gas or compression, you need all three...Get a used spark plug, plug it in to a plug wire and crank, see any spark? Next hook up a fuel pressure gauge to the fuel rail, turn key to on, any fuel pressure? Next use a compression tester, remove all plugs, take readings at all cylinders, crank so you get TDC 3 times in each cylinder, write down cylinder number and pressure.
Feb 11, 2008 at 7:11 AM
